    Automatik umbau auf Schalter | Forum
    hytech Driver
    hab mal ne auflistung von nem ammi kolegen für euch.
    hoffe das nimmt "euch den neuen" gleich die illusion das billig hinzubekommen
    Clutch parts:
    90363-12002-77 pilot bearing list 10.34 cost 7.90
    96152-00500 snap ring list 2.89 cost 2.21
    90560-50001 snap ring list 6.37 cost 4.86
    90560-79001 spacer list 2.57 cost 1.97
    90206-12006 wave washer list 1.71 cost 1.31
    90520-75001 snap ring list 3.26 cost 2.49
    31264-14060 spring list 3.26 cost 2.49
    31234-14020 spring list 2.17 cost 1.66
    90119-10054 bolt list .97 cost .74 x 2
    90080-11228 bolt list .77 cost .58 x 4
    Clutch Hydraulics:
    31470-14060 slave cylinder list 65.13 cost 49.73
    90080-10055 bolt list 1.00 cost .76 x 2
    31410-14310 master cylinder list 115.92 cost 88.51
    90179-08237 nut list 1.03 cost .79
    90080-11231 bolt list .60 cost .46
    90461-08702 clamp list 2.61 cost 1.99
    Transmission mounting/driveshaft
    12371-46110 trans mount list 74.88 cost 57.18
    90119-08770 bolt list 1.00 cost .76 ea x 1
    90179-08159 nut list 1.00 cost .76 ea x 1
    90201-11013 washer list .60 cost .46 ea x 4
    Shifter assembly:
    90301-11015 o ring list 3.17 cost 2.43 ea x 4
    33531-14010 boot list 42.47 cost 32.42
    90387-08134 collar list 2.11 cost 1.61 ea x 2
    33555-14110 boot list 34.32 cost 26.21
    33555-14100 boot list 10.66 cost 8.14
    33556-14050 seat list 1.69 cost 1.28
    93381-16016 bolt list .46 cost .39 ea x 4
    90179-08095 nut list 1.26 cost .97 ea x 2
    90105-08200 bolt list 1.00 cost .76 ea x 2
    91651-60835 bolt list .26 cost .20 ea x 4
    90105-08076 bolt list .86 cost .66
    90179-08233 nut list 1.14 cost .88
    90250-06026 pin list 1.18 cost .90
    90467-21010 clip list 2.84 cost 2.17
    96711-19033 x 2
    58261-14010 upper trans tunnel list 85.28 cost 65.11
    58994-14010 console bracket list 7.43 cost 5.68
    91651-60614 bolt list .71 cost .55 ea x 2
    58280-14080 boot/plate assy list 25.72 cost 19.63
    Brake pedal:
    47101-14230 brake pedal list 54.04 cost 41.26
    31321-14020 brake pedal pad list 3.49 cost 2.67
    78119-24020 gas pedal stopper list 13.92 cost 10.63
    Clutch pedal:
    31311-14120 clutch pedal list 46.21 cost 35.28
    90541-06036 cushion list .91 cost .70 ea x 2
    90949-03011 spring list 2.36 cost 1.80
    90386-13015 bushing list 1.49 cost 1.13 ea x 3
    90949-03013 spring list 13.69 cost 10.45
    31321-14020 pedal pad list 3.49 cost 2.67
    90101-10015 bolt list 1.11 cost .85
    90387-10003 collar list 4.92 cost 3.76
    31353-14010 holder list 3.60 cost 2.76
    90240-08006 pin list 1.86 cost 1.42
    90386-08010 bushing list 6.49 cost 4.95
    55107-14140 support assy list 83.25 cost 63.56
    91655-60630 bolt list .60 cost .46
    90119-08a22 bolt list .83 cost .64
    90082-61005 e ring list 1.69 cost 1.28
    94512-01000 washer list .72 cost .55
    94110-51000 nut list .69 cost .52
    90386-05017 bushing list 2.11 cost 1.61
    90206-08001 washer list .92 cost .70
    90468-16142 clip list .89 cost .69
    88280-14030 switch list 18.12 cost 13.83
    94120-41000 nut list .69 cost .52
    The transmission that I bought came with tripod and shifter. Instead of using the stock clutch line
    Plus : getriebe ca.3000 eus
    kardanwelle ca.400 eus
    diffi ca.1500 eus
    antriebe passenglaube auch nicht.nochmal nen paar euros.
    Clutch parts:
    Clutch Hydraulics:
    Shifter assembly:
    96711-19033 x 2
    Brake pedal:
    Clutch pedal:
    diffi ca.1500 eus
