    Kolben und Pleuel Gewichte | Forum
    Carsten Insider
    Bestimmt für einige hier interessant:
    Pistons
    STOCK - 86mm / 8:5:1 / Piston 407g / Pin 132g / Rings / Clips / Total Weight
    Mahle - 86.5mm / 8:5:1 / Piston 319g / Pin (.197" Wall) 103g / Rings 20g / Clips 2g / Total Weight = 444g
    Manley - 86.5mm / 8:5:1 / Piston 355g / Pin (.150" Wall) 106g / Rings 20-25g / Clips 2g / Total Weight = Approx 485g
    Probe - 86.5mm / 8:5:1 / Piston 335g / Pin (.126" Wall) 65g / Rings 20-25g / Clips 2g / Total Weight = Approx 425g
    Wiseco - 86.5mm / 8:5:1 / Piston 334g / Pin (.157" Wall) 112g / Rings 25g / Clips 3g / Total Weight = 474g -or- 494g w/.197" Pin Upgrade
    Arias - 86.5mm / 8:9:1 / Piston 355g / Pin / Rings / Clips / Total Weight
    JE - 86.5mm / 8:5:1 / Piston 330g / Pin / Rings / Clips / Total Weight
    Toda - 86mm / 8:6:1 / Piston / Pin / Rings / Clips / Total Weight
    HKS - 87mm / Comp? / Piston 384g / Pin 112g / Rings / Clips / Total Weight
    CP - 86.5mm / 8:5:1 / Piston 322g / Pin / Rings / Clips / Total Weight
    Crower - 86.5mm / 8:5:1 / Piston 338g / Pin / Rings / Clips / Total Weight
    Titan Street - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
    Titan Ultimate - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
    Titan Billet - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
    Greddy / Grex - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
    Tomei - 86.5mm / Comp ? / Piston / Pin / Rings / Clips / Total Weight
    JUN C Series (Cosworth) - 87mm / Comp ? / Piston 343g / Pin 104g / Rings / Clips / Total Weight
    JUN W Series (Wossner) - 86.5mm / 8:0:1 / Piston 362g / Pin / Rings / Clips / Total Weight
    Arias 86.50mm 355g
    Arias 87.00mm 362g
    CP 86.50mm 322g
    Crower 338g Bore: 3.405, +.020 - Comp: 8.5:1
    HKS 87.00mm Forged 384g Pin 112 Grams
    JE 86.50mm Forged 330g na
    JE 87.00mm Forged 333g na
    JUN C Series (Cosworth) 87.00mm 343g Pin 104 Grams - Cosworth part# PA1737
    JUN W Series (Wossner) 86.50mm 362g OE Comp 8.5:1 - Wossner Comp 8.0:1 - Wossner Part# K9057D050
    JUN W Series (Wossner) 87.00mm 362g OE Comp 8.5:1 - Wossner Comp 8.0:1 - Wossner Part# K9057D100
    Mahle 87.00mm 332.5g Pro Series Pistons
    Stock 86.00mm 407 Grams
    Rods
    STOCK = 761g with OEM Bolts
    K1 = 562g with 3/8" ARP2000 / Approx 566g with 3/8" Custom Age 625 / Approx 568g with 3/8" MP35N (like Carrillo's "Carr":wink:
    Manley H Beam = 552g with 3/8" ARP2000 / Approx 556g with 3/8" Custom Age 625
    Manley Turbo Tuff = 705g with 3/8" ARP2000 / Approx 709g with 3/8" Custom Age 625
    Brian Crower Pro Series = 608g with 3/8" Custom Age 625
    Carillo A Beam = 524g with 3/8" WMC
    Carillo SA ?? = 569g with 3/8" WMC
    Carillo H Beam = 600g with 3/8" Carr / 595g with 3/8" WMC
    Carillo H Beam HD = 606g with 3/8" Carr / 601g with 3/8" WMC
    Eagle ESP = 590g with 3/8" ARP2000 / * People always mention L19 bolts, but Eagle told me L19 is NOT an option on the Supra, only on domestics.
    Crower I Beam = 552g with ?
    Crower Titanium = 392g with ?
    HKS = 594g with ?
    Pauter = 680g with 3/8" ARP2000
    Pauter Titanium = ? with 3/8" ARP2000
    Brian Crower I Beam 495g Bolt 57g
    Carillo H beams 580g
    Carillo incl bolts 602g
    Crower Titanium 392g
    Eagle 594g
    Pauters 680g
    Stock Rod stripped 761g
    Stock Rod with bearing 800g
    Stock Wrist Pin 132g
    Pistons
    Arias 86.50mm 355g
    Arias 87.00mm 362g
    CP 86.50mm 322g
    Rods
    HKS = 594g with ?
    Eagle 594g
    Pauters 680g
